C287 series common squeak locations
  • copyrooks
    • Oct 2013
    • 210
    #16
    Re: C287 series common squeak locations
    Just wanted to add , ive had to grease up atleast 5 227s for that noise you guys are describing. Atleast its not a pain to pull out that section.
    • hotfuser
      • 180
      #17
      On this range they also clunk when just out of the box.
      They have a flat spot on the lower foller of the fuser.
      eventually the noise goes as it warms up luckily
      • vedder
        • 131
        #18
        This has already been confirmed by someone else, but removing that section and giving it a good lube has solved the squeak. Thanks for everyones input.
        • Cantechman
          • Nov 2008
          • 228
          #19
          Originally posted by EarthKmTech
          there is now special firmware for reducing duplex noise (slows down PPM speed in duplex, customer needs to accept this before installation) Available on request only, don't think they will release it for everyone
          I hear today they released a firmware for reduced fusing noise too ? Not sure what thats about.
          Old thread, but has anyone tried this firmware? I have a new install of a c287, it makes a fair amount of noise when doing the second side. Does this work? I was thinking it was a noisy motor.
          • habik
            • 2013
            #20
            Since the smartphone revolution I am recording everything NEW that makes noise or squeeks. I personally haven't come across this one yet, but if I do, I'll post the vid here.
            Firmwares HERE
            • Cantechman
              • Nov 2008
              • 228
              #21
              Good idea, I may try and get a audio recording of the noise tomorrow, try the firmware and post both results.
              • Vikingrepairguy
                • Mar 2017
                • 21
                #22
                noise from new waste toner box, white plastic exit rollers and yesterday had one at 17k with a squeak in the drum, took me awhile to figure that one out
                • Cantechman
                  • Nov 2008
                  • 228
                  #23
                  Fixed my issue by changing the duplex motor speed with a special firmware. It slows the motor slightly, not really enough to notice but the noise goes away.
