C6000 Wavy prints
  • Konicatech
    • Feb 2016
    • 131
    C6000 Wavy prints
    Hi all, I've got a c6000 that's producing wavy prints on anything under 140gsm stock. Bit stumped as to what's causing it, has anyone came across this?
    Ta
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: C6000 Wavy prints
    Humid paper?
    If using regular 75gsm try setting tray 1 step thinner. Less heat in the fuser.
    Also turn paper around landscape if you can see if the waves are less. Could be long vs short grain paper.
    • CopyJunkie
      • Oct 2012
      • 28
      I've had a deformed roller in the FS-612 cause a wavy paper issues on this model for me. The roller had expanded causing it to overdrive into the next set of rollers creating a wavy effect. With the finisher door open, I could see it pushing the paper up into a metal guide. Part number for the roller I replaced was 14JS45111E.
      Hope that helps.
      NOTES ON HOW TO USE THE FAX MACHINE.
      1. Get into your DeLorean (or your TARDIS) and go back to 1990.
      2. Place papers in the machine - Face Down.
      3. DO NOT dial 9
      4.
      Rejoin the rest of modern civilization.
      • tech51
        • 846
        The sprung loaded exit guide (can't remember it's actual name) in the fuser can cause this.
        It has a coating on it that peels off over time.
        • Konicatech
          • Feb 2016
          • 131
          Re: C6000 Wavy prints with example
          Hi guys,
          Fusing separation plate are you meaning? here is a picture of what its doing - it doesn't do this with heavier stock thoughimage1.JPG
          • tech51
            • 846
            The plate does cause this, generally on lighter weight stock although I've not seen it as bad as that.
            It would be worth replacing it, it only takes a couple of minutes
            • Konicatech
              • Feb 2016
              • 131
              Will try the plate and the one way gears in the fuser gearbox, hopefully if it doesn't cure it, it will at least improve it while I figure out what the hell is causing it
