BH C203 prints green super faint
  • aAandy
    • Apr 2012
    • 370
    hello people
    was called out to this machine for smudged prints
    this machine had a portion of the transfer belt edge support tape lifted, so i removed it - i also had to reshape the black mylar cover strips on each blank lamp assembly as they had been bent out of shape by the lifted ITB tape and were scraping the belt
    put it back together and all smudging gone, machine prints all single primary colours perfectly (cyan, magenta, yellow and black) but when i select the single colour green it comes out almost not visible where it was fine before (single colour blue comes out looking just cyan, single colour red comes out looking pink)
    also getting P21 which won't go away after cleaning the sensors & performing initialise & stabilization
    attached are sky shots in single colours - the blank one is green (can barely be seen by eye)
    BH C203.pdf
    thought anyone?
    thanks in advance
    • 23010
    Re: BH C203 prints green super faint
    Originally posted by aAandy
    ... put it back together and all smudging gone, machine prints all single primary colours perfectly (cyan, magenta, yellow and black) but when i select the single colour green it comes out almost not visible where it was fine before (single colour blue comes out looking just cyan, single colour red comes out looking pink)
    thoughts anyone?
    thanks in advance
    Well, clearly it's yellow that you're missing. Try printing off 15% fill images. It will tell you more.
    • aAandy
      • Apr 2012
      • 370
      i added an attachment to the original post - yellow is printing fine as a single colour
        • 23010
        What % fill? If you look at the gradation printoffs of the images in those attached documents you'll see that quality issue can affect different fill rates differently.
        I have a perfect example of that. On a KM-3551ci the Kyocera U089 Sample Set looked perfect, yet the quality issue showed nicely between 10 and 50% fill. Look at pages 5 and 6.
        • Synaux
          • Mar 2012
          • 1224
          As a side note, I have had the same thing with bad IUs
          I would suspect the PH, but if it was printing okay before (aside from the smudges), I would swap a transfer belt if you can and take another look at those IDC sensors.
          • aAandy
            • Apr 2012
            • 370
            thank you gentlemen for your responses
            returned to the machine, removed the imaging units & ITB assembly & found the rear ITB sensor cover was jammed shut - freed it, checked it didn't stick shut again, put it all back together and everything worked a treat
            no P codes and green printed perfectly
            thanks again for your input, very much appreciated
            Andy
