CMYK Printing out of place. Red Ghost printing
  • rapnex2000
    • Aug 2025
    Hello Good Day Everyone
    I have a konica Bizhub 652+ and having problems with the print output with red shadow ghost print on a full color print, even text have red duplicating shadow that are out of places. I don't understand the problem anymore
    my fusing unit is new
    my image transfer belt is new
    and also my 3 imaging units and drum are new CMYK
    i really need help. thank you very much.
  • REGSIS
    • May 2016
    • 435
    Re: CMYK Printing out of place. Red Ghost printing
    i will attach a sample print out[ATTACH=CONFIG]33809[/ATTACH]
    Depending of the nature of the problem you can try several things:
    1. Clean the sensors below the transfer belt. It is very important!!! and run image stabilization.
    2. Print head skew reset and after that Initialize + image stabilization
    3. Do the Color registration adjustment
    Hope it helps!
    P.S. Cyan and especially magenta seems worn (red lines). Are you sure they are brad new and not refubrished?
    • rapnex2000
      Hope it helps!
      Hello sir thank you for the reply,
      already cleaned the sensor below the transfer belt sir, and i already did image stabilization
      And the color registration adjustment won't start since the start button's color is orange not blue.
      i just installed 3 new imaging units yesterday brand new sir. and man do they cost a a lot =( hoping the problem would be gone but its still there.
      Can you help me out on how too Print head skew reset =)
      thank you so much.
      • rapnex2000
        also with the Cyan, Yellow and Magenta same exact white smudges
        • kingarthur
          • 1369
          The last time I had this, I carried out the skew adjustment & image stabilisation etc, it lasted 2 days, it needed FW to solve it
          • rapnex2000
            Hello sir Good day, that printer went back to normal printing for plain paper option after skew adjustment & image stabilization but when i printed on thick paper on thick 2 option, c2s 200 gsm it went back to the white smudges also for plain paper. =( =( =(
