This 364e is a used machine that my client bought. When connected to the network it says that "the ip address is already in use, contact administrator" however when the patch cable is disconnected from the network and the ip is pinged there is no response. This is a good sign that the ip address is not used anywhere else however when the cable is connected after a few minutes the machine says again that "the ip address is already in use, contact administrator".
I can log into the machine via the web browser however after a few clicks around the site the machine freezes.
I would like to ram clear this machine and install the latest firmware. Does any one have any firmware for this or any other suggestions.
Regards
Regards
