Konica C7000 have a problem with black color.
  • cxtqd
    • Jan 2011
    • 46
    Hello, KM C7000 have a problem with black color, it blurry (see photo attach).
    I have replaced the drum, charge, belt, transfer belt, develop, develop unit, laser K but all wrong
    Please give me any ideas to solve, thanks
    IMG_20160814_084133.jpgIMG_20160813_151835.jpgIMG_20160813_160433.jpgIMG_20160813_224828.jpgIMG_20160813_180008.jpg
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: Konica C7000 have a problem with black color.
    have you performed the several adjustments after replacing the printhead?
    • cxtqd
      • Jan 2011
      • 46
      I have adjustments Writing Initial Pos.., gammar adj, color registration
      • Synthohol
        • 5814
        here is the list of adjustments in case you didnt use the manual.
        good luck!
        each of them is inserted straight.
        6. Reinstall the above parts following the removal steps in reverse.
        7. After replacing the writing unit /K, conduct the following item.
        - Cleaning the dust proof glass (Refer to F.5.2.1 - Cleaning the
        dust proof glass)
        - Writing initial position memory (Skew initial position memory)
        (Refer to I.5.3.9 Skew Initial Position Memory (Printer Adjustment -
        Writing Initial Pos. Memory))
        - I/O Check Mode (LD1 to LD8 alarm data clear, LD alarm
        measurement) (Refer to I.5.7.1 I/O Check Mode)
        - CD-Mag. Skew Adj. (Refer to I.5.3.13 CD-Mag. Skew Adj.
        (Printer Adjustment))
        - Restart Timing Adjustment (Refer to I.5.3.1 Restart Timing
        Adjustment (Printer Adjustment))
        - Color Registration Auto.Adj. (Refer to I.5.3.10 Color Registration
        Auto.Adj. (Printer Adjustment))
        - Color Registration Manual (Refer to I.5.3.11 Color Registration
        Manual (Printer Adjustment))
        - Gamma Automatic Adjustment (Refer to I.5.4.7 Gamma
        Automatic Adj. (Drum Peculiarity Adjustment))
        - Beam Pitch Adjustment (Refer to I.5.3.14 Beam Pitch Adjustment
        - Moire Adjustment (Refer to I.5.3.15 Moire Adjustment (Printer
        Adjustment))
        • cxtqd
          • Jan 2011
          • 46
          Thank you Synthohol.
          I have done your way, I also have service manual for C7000, when replacing any parts I have to do the right process. But the situation doesn't improve.
          • silviux
            • Sep 2010
            • 14
            Excuse my English.
            I had the same problem on a C6000 and solved by replacing the NVRAM ( k laser beams out of sync )
            QUOTE=cxtqd;528249]Hello, KM C7000 have a problem with black color, it blurry (see photo attach).
            IMG_20160814_084133.jpgIMG_20160813_151835.jpgIMG_20160813_160433.jpgIMG_20160813_224828.jpgIMG_20160813_180008.jpg[/QUOTE]
            • cxtqd
              • Jan 2011
              • 46
              Replace NVRAM means you have to have a different C7000?
              • silviux
                • Sep 2010
                • 14
                No, it means that for the NV Ram must contact KonicaMinolta
                • cxtqd
                  • Jan 2011
                  • 46
                  Thanks Silviux, I don't think so NVRAM.
                  I'll check it again.
                  Have you any other idea?
                  • silviux
                    • Sep 2010
                    • 14
                    [ATTACH=CONFIG]33886[/ATTACH]
                    Printer image processing board
                    Printer control board
                    you have tried to reverse the k laser wiring that goes to Printer image processing board with another laser ?
