C308 papercut integration issue after MFP board change.
  • wseyller
    • Sep 2012
    • 1129
    Had to replace the mfp board on this model for other issues.
    But now I am unable to get papercut to install the application.
    Tried clear data a couple times. Set hard drive back to installed.
    I setup everything back up with manual entry. Network settings are exactly the same. Turned on Web Browser function and confirm it works.
    Server and copier can communicate.
    Created self sign cert. Turned ssl to admin and user mode. Turned off certificate verification. Turn on ssl for tcp socket. Turn on ssl only for openapi and set do not request and do not confirm. Rebooted when told to.
    Tried latest base firmware and latest special firmware and also the firmware that was used before board change which was GG5-54. Tried all combinations of functional levels from 2.0 to 2.2
    In papercut device status I get a message of:
    Started (with errors) - There was an error communicating with the device. Setup will be retried at 11:59:24AM. To retry now, press "Apply" below.
    Error: setApplication: error=29, message=CMS MFP Setting Check Error.
    You can see the copier trying to install but gives up. You can see that papercut tries again every few seconds.
    Customer has papercut 15.2 with a C258 and some E series working ok on Papercut. I also tried it on my version 16 papercut installed on my laptop and got the same error.
    Using openapi 3.1+
    Also tried installing Bizhub market place just to confirm an app that uses web browser would work and it installed very easily.
  • habik
    • 2013
    Re: C308 papercut integration issue after MFP board change.
    Is the machine set with correct machine & type settings ( when loading firmware) ?
    Have you got the SATA controller Driver updated to G00-04?
    The latest base FW G00-E1 ( could be set to ver. 3.0, bear in mind new driver, voice data.. Etc)
    Is the device in PCUT set with correct user ID&password
    Whats the lease lenght of the certificate?
    Does web browser use ssl 3.0?
    Can you turn remote panel ON from your laptop?
    Have you tried Open API 4.0?
    Have tried DHCP on network and if, was it successful?
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • habik
      • 2013
      Try setting the SSL to Admin mode only.
      Firmwares HERE
      • wseyller
        • Sep 2012
        • 1129
        It is set with correct machine type per the service manual during first boot.
        Sata is up to G00-04
        Latest base you mention I didn't know was available as it just came out. But I have so many of these that work on G00-84. But on next visit I would like to try anyway.
        Yes for sure the user is "admin" as always and I changed the password to "12345678" which I have logged in many times with on copier and pagescope web. I used the same password several times and I have created the device many times on two different papercut servers.
        Cert encryption strength is default. On hundreds of machines I've setup that has always worked which is what the papercut manual suggests.
        Not sure what version SSL the browser uses. Never had to worry about it.
        Never used remote panel before so I'm not sure.
        I didn't try api 4.0 but it did cross my mind at one point but technically api 4.0 isn't support in the US and papercut support told me not to use it. But it is definitely worth the try.
        This customer elected not to have dhcp available, so it never worked with any of the devices we had set up. Plus it didn't work connected to my laptop's papercut application server and it should have work with it.
        Customer has more of these same models onsite and I have compared all these settings and can't find any difference so far.
        I will try "admin only" for ssl just to satisfy but I have never had to do that before
        I am heavy into papercut setups and have done so many. It kills me because I have yet had one fail on me until know. I've had problems before but some of those I feel that the copier was screwed up during setup and I've been able to get it to work with at least a factory reset and set it up myself.
        Sent from my Nexus 6P using Tapatalk
        • habik
          • 2013
          Was it a new MFPB or from a different machine?
          Trying the remote panel is to check if the SSL is set and accepted and working.
          How about backup data on another C308 or C258 and copy it across to this one even with the same IP, whilst having the other disconnected.
          Sorry dude, I am running out of options as what to suggest. I feel your pain. Wish you best of luck.
          What does PCut knowledgebase know about that error?
          Firmwares HERE
          • wseyller
            • Sep 2012
            • 1129
            It is a new board, not cleansed or repaired. The marketplace app I figured does the same to check SSL.
            The papercut KB doesn't list error it seems.
            I sent debug log to papercut support.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Did you remember to set the clock after replacement of the mfp board ?
              • Synthohol
                Certified Konica Expert
                • 5905
                Since the board change the network MAC address has changed. Dies PCut go by MAC or IP?
                Hope thats your answer.
                • wseyller
                  • Sep 2012
                  • 1129
                  I did set date/time but I did that in admin mode. I didn't think to check in service mode so I will check that out. Papercut uses the IP address to connect.
                  • B0265
                    • Jan 2007
                    • 718
                    I don't know Papercut but it might be related to this:
                    Encrypted client (PC) to server (KM device) SSL/TLS sessions cannot be performed after installing the following update to the PC:
                    June 2016 update rollup (This program was discontinued due to the release of the July 2016 update rollup program.)
                    KB3161606 (Windows RT 8.1, Windows 8.1, Windows Server 2012 R2)
                    KB3161608 (Windows 7 SP1, Windows Server 2008 R2 SP1)
                    KB3172614 (Windows RT 8.1, Windows 8.1, Windows Server 2012 R2)
                    KB3172605 (Windows 7 SP1, Windows Server 2008 R2 SP1)
                    Cumulative update for Windows 10 (June 14, 2016)
                    KB3163017 (Windows 10)
                    KB3163018 (Windows 10 Version 1511, Windows Server 2016 Technical Preview 4)
                    • tech51
                      • 846
                      I read a bulletin on this today.
                      There is a dip switch that has to be changed.
                      Can't remember which one and I've finished work for the weekend now but it was an official KM bulletin so if you have access to the KM site it will be there.
                      • wseyller
                        • Sep 2012
                        • 1129
                        Funny because I had to also change an E series board that now comes with a dip switch.
                        I looked in tech bulletins and also searched knowledge base for key words "mfp board" & "dip switch" with no luck. Does someone know where I can find it.
                        • tech51
                          • 846
                          It's not a physical switch, it's a software switch.
                          • wseyller
                            • Sep 2012
                            • 1129
                            Are you talking about softswitch 25 to change functional version or some other switch.
                            • tech51
                              • 846
                              Back at work now!!!
                              The dipswitch is soft switch 43 set to hex 03.
                              This applies to the 4,7and 8 series machines.
                              I will try to find the bulletin number later.
                              Hope this helps...
                              Bulletin numberTAGB1600365EN
