Bizhub 363 Fusing Lamp
  • richmods
    • Aug 2013
    • 91
    I was wondering if anyone has had any luck finding the heat lamp for this model fuser. I currently have one with a busted element and would like to order just the lamp as the rest of the fuser is just fine. If anyone one knows of or has a supplier I would be greatfull if you would share that info. Thanks in advance.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4637
    Re: Bizhub 363 Fusing Lamp
    Did you try buying a used fuser on Ebay, etc. You can use lamp from any machine in that series, Biz 223,282,363,423.
    Not sure but may be able to use a lamp from the Biz 200 series.
    • richmods
      • Aug 2013
      • 91
      have one on the way...actually had a lamp in the shop but it was broken as well. I don't have many of these in the field so I don't carry many spare parts for this model.
      • Don N.
        • Nov 2011
        • 409
        Lamp ends and holders are physically different, but if we keep getting these lamps opening a filament, I may dremel the holder to fit an older model lamp with similar wattage and splice in.
        Love to hear about any other's success?
