Konica Minolta C280 Firmware - Error Code C152
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C280 Firmware - Error Code C152
    Updated the firmware and getting Error Code C152 on Konica C280.
    Do anyone can send me latest firmware GCZ-D1 etc. Please also advise about the Right File System for USB (FAT or FAT32 etc.)
    Thanks a lot.
    mearmi@hotmail.com
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica Minolta C280 Firmware - Error Code C152
    Thanks a lot.
    mearmi@hotmail.com
    fat32 and use a USB2 usb drive with no more than 8GB
    also if ur deprate i have a very old firmware file herer https://www.dropbox.com/s/oelmyay463...0EDFW.tar?dl=0
    but if no one else helps u out i can put on the latest one later
    • mearmi
      • Oct 2010
      • 350
      Thanks a lot for your reply.
      I tried the same file and got C152 on the copier.
      This USB was working fine but have another issue now, using 4GB USB but it gives error "This is invalid external memory"
      Please advise and also send new firmware.
      Many Thanks
      mearmi@hotmail.com
      • copier tech
        • 8174
        Was the machine working OK before you updated the firmware?
        Here's the latest FW, give this a try. I only use 2GB USB dives on these on C288/C552's
        MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
        • mearmi
          • Oct 2010
          • 350
          Yes it was working.
          • mearmi
            • Oct 2010
            • 350
            https://mega.nz/#!hF0Q1SDZ!z-ShY2YSa...ZYXS8pEPDqpgaw
            Thanks a lot for the FW. Tried 4 USBs. Not even one worked.
            Think the problem is in MFP/Formatter Board,
            Regards,
            • rrrohan
              • Sep 2011
              • 1977
              Is it giving invalid memory error
              • mearmi
                • Oct 2010
                • 350
                Thanks for your reply.
                Yes it is giving "This is invalid external memory"
                Regards,
                • habik
                  • 2013
                  When formatting stick as FAT32 call it something.
                  Byting on bits.
                  Firmwares HERE
                  • rrrohan
                    • Sep 2011
                    • 1977
                    You can get that error if the firmware your using is incorrect. Is it GDC-D1
                    Sent from my SM-G900I using Tapatalk
                    • mearmi
                      • Oct 2010
                      • 350
                      Byting on bits.
                      No Luck
                      • rrrohan
                        • Sep 2011
                        • 1977
                        if worse comes to worse i can post you a known working usb stick with firmware on it. I used it today so atleast then youd know if its bad usb or not
                        • mearmi
                          • Oct 2010
                          • 350
                          Thanks a lot
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Just checking you are extracking the A0ED.tar file not leaving it as a zip? Just have to ask as cant assume you familiar with KM firmware update procedures
                            • nking58
                              • May 2009
                              • 6
                              If you still havent gotten the firmware to load, I can provde a URL and credentials to allow use of internet ISW as long as the machine can get out to web on port 21.
