I have a C754 with a LCT, LU301
When selecting the LCT tray ,the messgae states " select paper size".
Have checked the setting under system 1 in Service mode.
Upper limit and paper sensors change state correctly.
Interlock switch is working.
Transport motor works.
When I fill the tray with paper and close the door , Nothing happens. Tray should raise but it doesnt.
Theory of operation, says, When the door is closed the system checks the state of the upper limit switch and that switch checks good.
Anyone have any suggestions as there is no troubleshooting procedure for what is happening.
