Drum unit to be changed
  • karthik2808
    • Aug 2025
    [Error Code] Drum unit to be changed
    Dear All,
    Am using Konica minolta bizhub C224 model, it showing some error like "Y drum unit to be replaced". But i have bought new one and inserted.
    But the issue remains the same. The error message is not going at all.
    Please guide me to kill this issue.
    Thanks in advance.
    Regards,
    Karthik
  • Synthohol
    Certified Konica Expert
    • 5854
    Re: Drum unit to be changed
    was it a real OEM drum unit or did you just replace the cylinder?
    the new? chip did not communicate to the machine. check the gold terminals on the copier.
    • karthik2808
      Thanks for your response. will try it and tell you the status.
      Regards,
      Karthik
