Ok, so this machine is a dinosaur, 5m on it and running like a champ. Picked up a C6501 full boat for cheap for a dedicated heavy stock printer, ended up parting it out to keep other machines running.
Everything works, so I don't get it. Tray will not unlock, when you pull the handle you hear the solenoid click.
Tested I/O and can make them pop as well. Cleaned the top sensors behind the feed on Tray 5 and it started working for a hour, then went back to not unlocking.
From my limited knowledge I think the only reason they lock is if it senses paper exiting the tray.... may be wrong.
Any direction before I go crazy
