Bizhub 601 Display is flashing ON and OFF
  • Gabriel
    • Jun 2006
    • 141
    I got a service call the problem reported was paper jam in tray 1
    I shutdown the copier, replaced set of 3 roller in tray 1
    Power ON the copier and...
    You can hear the fans, the start button is flashing red/blue
    and display is few seconds ON and few seconds OFF also there is a clicking noise from relays
    That's all, no service code. Nothing!!!
    Document feeder and the finisher are unplugged
    Not able to get into service mode or trouble reset function.
    Not sure if memory RAM, CF Card or NVRAM could be the offending parts.
    I never had this problem and not sure how to troubleshoot it.
    Any help is welcome
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 601 Display is flashing ON and OFF
    Try to open the front doors and disengage the ADU before switching on.
    Unplug things like the HDD and every thing that's not needed at power up.
    Whatever
    • Gabriel
      • Jun 2006
      • 141
      Thanks Allan
      I just removed the hard drive and disengaged ADU unit
      Tested the AC voltage (It is fine and stable 120VAC)
      Keep open all doors and power ON the copier.
      Machine still doing the same
      I'm Running out of ideas
      • allan
        RTFM!!
        • 5462
        Reinstall firmware? Maybe a bad CF card.
        Whatever
        • Gabriel
          • Jun 2006
          • 141
          Thanks Allan
          Not sure if I can get it but I'm going to try
          • Sriyanjan
            • Apr 2015
            • 79
            I have no experience in konika . But it sounds like short circuit inside machine .
            So i think you should remove fuser unit and logic board power connecter . Then check again .
            Sent from my HTC Desire 820s dual sim using Tapatalk
            • Gabriel
              • Jun 2006
              • 141
              Updating the firmware fix the problem
              Thank you
              • Synthohol
                Certified Konica Expert
                • 5892
                Thanks for the follow up!
