+368
  • CrapAimer
    • 296
    hI
    Having trouble upgrading the firmware on a +368, keeps coming up this function is not available anyone came across this before, tried formatting the stick and putting it back on but still the same
    Thanks George
  • emujo
    • Jun 2009
    • 3009
    Re: +368
    It sounds like you are not pressing the stop key at power up with the USB stick inserted into front port( should see a small black dot while MFP boots to firmware up mode). You would get this message if you inserted a USB stick while the MFP was still prepping the user box/scan modes. Emujo
    • CrapAimer
      • 296
      Re: +368
      Got the wee black dot ?? weird one
      • mo0651
        • 1054
        Re: +368
        Are you leaving the front door open??
        • Woxner
          • Jul 2011
          • 847
          Re: +368
          front door does not need to be open . make sure the folder is Fw001 leave all the files in this folder after it is unzipped. try a smaller usb. biggest i have used on these is 16 gb
          • rindraintsoa
            • Sep 2010
            • 55
            Re: +368
            Hello all,
            we have also the same problem, if anyone can help it will be great.
            • HuronMan
              • Jul 2009
              • 68
              Re: +368
              I had to flash one of these things to get rid of the b003's, a couple of weeks ago. I tried 3 different drives. A 2G and 2 16G's. I went and bought a new Sandisk 16G and it finally worked. I dunno.
              • rindraintsoa
                • Sep 2010
                • 55
                Re: +368
                hi all,
                I have tried diferent sticks but with no result. I found always the black dot in the right corner, and the machine is not responding like it is making an infinite loop. Anybody have a suggestion?
