Konica C220 slow to start printing
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I have a client who complains that the printer takes a while to start printing PDF's which are only say 840KB in size.
    I have asked them to send over the PDF and they are actually scanned documents. There is only a small logo on each page..... i have printed the PDF in black and white and it prints out more or less straight away however it does take between 3-4 minutes before it starts to print.
    Could this be a memory issue?
  • jotunn
    • 614
    • allan
      RTFM!!
      • 5462
      Re: Konica C220 slow to start printing
      Try using pagescope direct print.
      PageScope Direct Print - PageScope Utilities - Solution Software | KONICA MINOLTA
      Whatever
      • tech51
        • 846
        Make sure the spool setting on the driver is set to print after last page is spooled.
        If it's set to print directly to printer or print after first page is spooled, it will make the machine appear to print slowly but its the way the data is sent that is causing the issue.
        I assume the network speed is good and stable i.e. not wireless ?
        • copier tech
          • 8142
          How long is the delay before it prints the pdf? Compared to printing a say word doc pdf files always have a delay before they print (reason as stated above.)
          I have found updating the firmware & the drivers helps this issue.
