Konica 222 that top tray is not feeding. Replaced feed clutch and everything in that pack. Copied worked fine. Next day tray did not work again most of the time. Bottom tray works fine. I thought feed clutch drive both trays.
Is there another clutch on the feed unit itself and by chance would you know if parts off of a 350 are the same?
Thanks ahead of time, for any help.
