Bizhub C368 - Faded out areas only when scanning to email or User Box
  • mx6turbo89
    • Oct 2013
    • 154
    [CQ] Bizhub C368 - Faded out areas only when scanning to email or User Box
    This one stumped me today:
    Document is being scanned to email and is showing up with various letters or words faded out (please see the attachment). The problem also shows up when scanning to a User Box. It copies and prints this same document just fine. It's being scanned at 200x200, and the file type is Compact PDF. This customer has a C368 upstairs and it does fine when scanning this very same document when using the same settings. Also, this problem is very consistent; it may vary slightly, but it's pretty much the same area of faded letters/words every time regardless of whether the original is fed right side up, upside down, or in the 11R direction. It doesn't matter whether I scan in black or color, same result. Changing the file type to PDF still shows the faded letters. I've found that if I increase the scan resolution to 600x600, the problem almost goes away, but there are still a few letters faded out.
    Any thoughts? Anyone seen this before?
    Example.pdf
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C368 - Faded out areas only when scanning to email or User Box
    Weird.
    Try changing the original type.
    Whatever
    • mx6turbo89
      • Oct 2013
      • 154
      Originally posted by allan
      Weird.
      I tried that, didn't make any difference. Thanks.
      • progoffice
        • Nov 2008
        • 334
        Have you tried changing the Compact PDF Compression level?
        • mx6turbo89
          • Oct 2013
          • 154
          Changing the setting from Compact PDF to PDF fixed it. Thanks very much.
          Edit: Just reread my original post and I claimed to have already tried changing to the PDF setting with no resolution. I did try it then, it didn't fix the problem that day, but for some reason fixed it today.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Not a fault and is a known issue. Same thing happens with hand written signatures. Last I heard km wont be doing anything about it either. Hopefully they do because people are noticing it when upgrading from e series to 8 series and require compact pdf.
            • mx6turbo89
              • Oct 2013
              • 154
              I had not heard of this specific issue being a known problem. But, I have heard a few customers complain that the e-series they had previously had better quality scans than their new 8-series. In a few cases, I've had to increase the default scan resolution to equal what their previous e-series machine accomplished on the lowest setting. What is the theory as to the cause of this?
