Bizhub 42 ccd
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Bizhub 42 ccd
    This is a long shot but I have a ccd that is drawing a line down the page. Nothing on the slit glass, so I open the scanner and tried wiping mirrors with a soft cloth. It seemed to get lighter and by the third time it was almost gone. One more wipe and it came back darker than ever. I opened the mirror area and looked and it looks like a tiny scratch in the same area where the line is. How a mirror gets a mark on it, on a unit that had never been opened, is beside me. Manager thinks it must be something else. Machine has 500,000 on it. Has anyone else had a similar issue?
    On the c35, the scanner part numbers are different but the ccd's look the same. Does anyone know if they are?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 42 ccd
    What color are your lines.
    If its grey or like green its optics.
    If they are pure C or M or Y or K it could be something else.
    Whatever
    • Albonline
      • Sep 2008
      • 1153
      Re: Bizhub 42 ccd
      They are the same. the cable location to the main body from the scanner unit is whats different between the two scanner units.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Re: Bizhub 42 ccd
        The lines are black. Also seem to go away sometimes. Came in this morning and made a set of ten copies, no line. Did it again and every page has a line.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Re: Bizhub 42 ccd
          To close this thread...go back to the basics. I had a case of tunnel vision and got off track. Everyone from the customer to another tech to the manager verified the slit glass was clean. That along with a mark on one of the mirrors in the same spot where the line was, got me off track. I went in with a magnifying glass and a good light and with the expectation of finding a burr on something. What I saw was the most tiny insignificant spec on the slit glass. Removed it and the line was gone. I was amazed because it was drawing a line much wider than it was and very dark.
          • Brett GS
            • Jun 2013
            • 154
            Re: Bizhub 42 ccd
            The c35 optical unit works on the B42/B36 fine,the ribbon cables are abit longer but not an issue.
