C3350
  • antone
    • Oct 2014
    • 344
    C3350
    Fuser trouble code...replaced fuser with new one.... nothing code 3411...do I need to reset ....can't find anything in SM
    Sent from my SM-N920V using Tapatalk
  • mx6turbo89
    • Oct 2013
    • 154
    Re: C3350
    I can't find a 3411 either, but try this:
    1. Turn OFF the main power switch.
    2. Turn main power switch ON while pressing the Power key.
    3. If a trouble code appears, press the "Menu" key on the control panel.
    4. Touch the password input area and, using the keyboard on the screen, type the CE password.
    (The initial setting for CE password is "92729272.")
    5. Touch [OK].
    6. Touch [Trouble Reset].
    7. Touch [OK] on the check screen.
    8. According to the description on the screen, turn off the main power switch, and turn it on again more than 10 seconds after and check if
    the machine starts correctly.
    • habik
      • 2013
      Re: C3350
      5. Touch [OK].
      Is this trouble reset any different to holding down the reset key? As with that you don't have to go through the CE authentication.
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • mx6turbo89
        • Oct 2013
        • 154
        Re: C3350
        I suppose the end result is the same, it's just a different routine to get there. This isn't the only way, but is the easiest way to perform a trouble reset in this model.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4780
          Re: C3350
          Originally posted by HerbertFultz
          One of the cementing file work is done for the top of the turns. The joy of the افضل دكتور نفسي اون لاين is pushed for the game. The schedule is ensured for the reforms. Path is filed for the advancement for the turns.
          I sent a message to admin to delete this troll's account.
