1060L Installation question
  • DigiMan
    • Jan 2013
    • 262
    [Misc] 1060L Installation question
    Goodmorning everyone!
    Kinda silly question actually but im going to install a 1060L in a couple of days and i was going through the new installation manual.
    I noticed when you are done with the screws etc and you turn the switch on it says touch startup then package adjustment and after a while
    Color adjustment(Which is described in the SM).Question is what exactly is covered in the "package adjustment" and what must you do for the color adjustment?In the color adjustment in the service manual it covers like 100 topics,what exactly must be adjusted?
    Thank you in advance!
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5892
    Re: 1060L Installation question
    pkg adj does everything, do it at install and every PM.
    Package adjustment
    Following adjustment items are performed automatically in the order.
    (2) Usage
    Use the overall adjustment when you want to perform various settings at once after the installation.
    (3) Procedure
    1. "Service Mode Menu screen"
    Press [18 Startup Setting].
    2. "Startup Setting Menu screen"
    Press [01 Package Adjustment].
    3. "Package Adjustment menu screen"
    Press [Start].
    4. When the message "Adjustment after unit replacement is completed." is displayed, press "Exit".
    • DigiMan
      • Jan 2013
      • 262
      Package adjustment
      (2) Usage
      (3) Procedure
      Press [Start].
      Thanks synth and sorry for the very late response!
