Konica 454e
  • antone
    • Oct 2014
    • 344
    Konica 454e
    PC..410..Jams..J1601..Changed complete paper feed unit,pwa board!Swapped PC...410..put in another copier..still the same....also firmware updated
    Sent from my SM-N920V using Tapatalk
  • guitar9199
    • Sep 2016
    • 1100
    Re: Konica 454e
    Out of curiosity, does this model have the clear plastic guide plates in the vertical transport area, and are they mounted correctly? I've seen some from the C220 and C353 series that one of the mounting posts on either side is warped or broken off, which can lead to vertical transport jams. Konica Minolta came up with a front and rear support piece that keeps in from happening in the future, but it might be worth looking into.
    • antone
      • Oct 2014
      • 344
      Re: Konica 454e
      Vertical transport is black..also sep ..and feed rollers turn!ONLY paper pulls out half inch or so.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: Konica 454e
        Did the fault travel with the tray or did it remain with the machine when you swapped the PC-410 with another machine ?
        • Albonline
          • Sep 2008
          • 1151
          Re: Konica 454e
          have seen these where the motor bracket has warped and gear mesh becomes either too tight or starts slipping,also the rollers in the door can bind or dislodge.
          • antone
            • Oct 2014
            • 344
            Re: Konica 454e
            Both machines doing the same jam J-1601...very crazy
            • Trigger
              • Aug 2014
              • 16
              Re: Konica 454e
              Theres a one-way clutch which drives the vertical transport rollers on the PC-410. Theres a known issue with it and seeing as your jam code corresponds to the PS133 sensor not detecting the ledge edge i'd definitely look at that
              • joelea
                • Feb 2012
                • 64
                Re: Konica 454e
                Push the side door as it's feeding and see if it improves. If it does you might need to pack it out with washers to get it to feed properly. We had this and we fixed it doing that.
                • hosman80
                  • Jun 2008
                  • 38
                  Re: Konica 454e
                  Did you find the problem here? I'm heading to a machine with similar issue...thanks
                  • Miller
                    • Nov 2015
                    • 3
                    Re: Konica 454e
                    I just tackled this same issue on a PC-410. I actually found if you take the back off the PC-410 you can visually see that the paper is lifting to high applying to much pressure on the paper stack to feed. I swapped the drawer for tray 3 and it resolved the issue and upon inspection from the back I can now see that the paper is lifting to the correct position. It now feeds properly. I expect the paper lift sensor for tray 3 or the cable mechanism to be at fault but didn't do any further repair of the tray. I hope this helps you with your J-1601 code. For reference the machine model was a Bizhub C554e.
