C552 drum swap error
  • mrfuser
    • 1598
    Took a good set of drums from a c552 and installed a couple in another c552 with a couple of bad drums. We now get a c2554 and c2556 error. Some reason we can't swap drums from one machine to another? Same exact model machines.
  • allan
    RTFM!!
    • 5459
    Re: C552 drum swap error
    You have to change the chips with new ones when you change the units.
    The toner to carrier ratio on the units are different that is the reason for your codes.
    It will initialize the TCR value when it reads the new chip and the IU's will work or not.
    Whatever
