Prints skew and duplex not aligned
  • photocopier.technician
    • 27
    Hello
    I am having lots of problem with a biz hub C224e. The prints are skew and also the duplex are not aligned. I checked in the service manual and did the below alignments
    1. Printing area Leading adjustment
    2. Printer registration loop adjustment.
    3. Print head skew Reset
    None of these have solved the problem.
    I have replaced the registration roller assy, but no success.
    I attached a sample one sided print and the skew is very well visible.
  • allan
    RTFM!!
    • 5462
    Re: Prints skew and duplex not aligned
    Same result from the bypass?
    You can try to realign the transfer roller section and the door.
    Put some pressure on the door while printing to check if there is any change.
    Had a C554 with the same problem. Got it better but not correct.
    Would like to know how to get it perfect.
    Whatever
      • 14532
      Is this a print or a copy? Could it be DF skew?
      • Albonline
        • Sep 2008
        • 1144
        what he said?
          • 27
          The problem is when doing a prints. I will try to to realign the transfer roller section and the door and keep you updated.
          • Mohamed Mesbah
            • Sep 2024
            • 32
            Any updates please ? I have the same problem
