C452 / IC-412 prininting banners from Mac
  • B0265
    • Jan 2007
    • 718
    Does anyone have a guide on how to print banners on a C452 from a Mac using the Fiery controller?
    Had a call from a customer that get "memory overflow" in the job history when they try.
  • habik
    • 2013
    Re: C452 / IC-412 prininting banners from Mac
    Try this from the standard MFP controller, then try from Fiery :
    http://www.copytechnet.com/forums/ko...tml#post391163
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • 5857
      To print a banner, ensure the printing application is open and then select the following:
      1. Select "File".
      2. Select "Page Setup".
      3. Select "Paper Size".
      4. Scroll to "Manage Custom Size".
      5. Press the + key and an "Untitled" listing is shown. Double click on "Untitled", type the name "Banner" and set the width and height accordingly.
      6. Press OK twice to exit.
      7. Select "File" and "Print".
      8. Select "Paper Tray/Output Tray".
      9. Select "Paper Tray" and set to "Bypass tray".
      10. Select "Paper Settings for Each Tray" and set the paper type accordingly.
      that's for MAC 10.6, may work on others, i dont know.
      could also just send it to the hold queue and verify the settings and print through CWS, may help because the file is already on the server (fiery)
