Bizhub 7272 Touch Screen
  • nikheps
    Help!!
    I made the mistake of stumbling into the Control Panel calibration screen in Key Operator Mode.
    I touched the corners, then the check-boxes, heard the beeps... But now the screen doesn't recognize any touches, which of course makes it impossible to re-enter Key Operator Mode & attempt to re-calibrate.
    Ugh!! Any work-arounds?
  • Albonline
    • Sep 2008
    • 1153
    To adjust the LCD sensitivity, perform the following:
    1. Press the Help key and then Press Key Operator Mode on the touchscreen.
    2. Press selection [10] on the LCD to access the control panel adjustment screen.
    Note: If the touchscreen is so far out of adjustment that there is no response when pressing [10], the control panel adjustment can be accessed by touching any numeric key on the key pad. Two plus symbols (+) should be visible on the screen.
    3. Touch [+] at the upper right corner lightly with a touch pen (something with a round tip made of resin is recommended).
    4. Touch [+] at the lower left lightly with a touch pen.
    5. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. A beep sound should be heard for each one. If a beep tone is not heard, repeat the adjustment.
    6. After the adjustment is complete, press the [0] key on the numeric key pad.
    7. Power the machine OFF to store the adjustment. Power the machine ON normally and check operation of the touchscreen.
    Note: It may be necessary to repeat this adjustment procedure several times to achieve proper LCD sensitivity.
    • nikheps
      I'm with you...
      The problem is when I hit the Help button, I cannot deliberately select anything on the screen. I'll poke at it like a frustrated chimp and it will eventually get me into some random sub-menu. But I'm never able to tell the machine that I want to get into Key Operator Mode in the bottom-left corner.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        I believe if you hold down the help key while powering on you will go directly into keyop mode.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • nikheps
          Aha! That did work, Thank you!
          Now I just have to get the checkboxes to fall within range, but they seem SOOO out of whack!
