Web cleaning Bizhub 500
  • Astermarc
    • Mar 2009
    • 46
    Can anyone tell me how change the speed of web cleaning on bizhub 500? Or maybe how which is the code in load check to see if web cleaning is working.
  • copyrooks
    • Oct 2013
    • 208
    Re: Web cleaning Bizhub 500
    there's a load check option for web solenoid (sd4)
    code:53
    multicode:0
    hope that somewhat helps
    • Astermarc
      • Mar 2009
      • 46
      Thk a lot! I wasn't sure. I already try this code. When I push start, it makes a noise and on screen it's said OPERATING but when I press stop nothing heard. I guess I need new solenoid.
      • Synaux
        • Mar 2012
        • 1224
        It should only click once when initiated and once again when you exit.
        Rig it so you can open the front door and take the cover off to physically see if the web is turning (it will be very little).
        Also, if its like the newer models, if you performed a PM, make sure you reset the counter for the web in service mode or it will not turn
        • Woxner
          • Jul 2011
          • 842
          got to say never heard of this failing
          • Astermarc
            • Mar 2009
            • 46
            Trust me, it's very annoying. Every time, when the copier it stays for a period of time, I get a C-3201 code. So to solve this, I need to rotate manually the web cleaning and then it works. Try to do this 2-3 times/day when you have a full day.
