konica 361 c-2409 code
  • DOE
    • Mar 2010
    • 258
    have a Konica 361 that allows you to make copies for about 2 min. and then you get a c-2409 code. sounds like a toner motor problem because you can hear something continue to run for the 2 min. I don't have service manual to look up code to make sure and when I google c-2409 nothing comes up for that code. I see a c-2404 I think has to do with toner motor. can anyone confirm that a 2409 is a toner motor problem. thank you
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: konica 361 c-2409 code
    check your PMs
    manual does not show that there is a C-2409 code.
