Printing Problem - Konica Minolta biz hub c451 (Shades)
  • matsan_offset@yahoo.com
    • Sep 2016
    • 43
    Hello,
    I have problem with my K-M BizHub C451. Everything going ok till first 50-60 (approx.) prints but later on it start to give shades on both BW and colors.
    Also at white parts of image or empty pages it gives very light yellowish/reddish (in color prints) and greyish (in B&W prints) colors.
    Do you have any idea of the reason?
    Thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5854
    Re: Printing Problem - Konica Minolta biz hub c451 (Shades)
    in service mode, test prints, gradation pattern c/m/y/k print them out, may help isolate the problem.
      • Sep 2016
      • 43
      • Flash
        • 378
        I would say the black imaging unit is shot.
          • Sep 2016
          • 43
          So if we change this unit, will the problem be gone?
          • darry1322
            • Oct 2010
            • 817
            The black unit is bad. Replace that unit, do the color alignment, and gradation adjust. See what you've got from there.
            • Synaux
              • Mar 2012
              • 1224
              Make sure to add something to the lever to push the K IU all the way in or buy the mod (there are many posts about this).
              From the looks of it, the black IU is most likely spewing developer. If it is leaking dev, take it out to see if there is any developer on or around the IU (use a magnetic screwdriver to see if it clings--if it does its dev and not toner).
              If this is the case you need to clean the IU cavity, as well as the Print Head and the yellow IU! When I see dev spew I personally also clean the IDC sensors and transfer belt.
              Also, I am willing to bet your yellow IU is bad--destroyed by the dev.
              Also:
              Go in service mode > counter > life
              Post the life of the IUs
              (If it is spewing dev. you might also have a bad HV board.)
              • 1FRY1
                • 51
                Matsan
                Do I take it you are a user rather than a technician ?
                • MFPTech
                  • 486
                  This is a typical user response. You are not a tech, are you?
                  Sent from my SGH-I337M using Tapatalk
                    • Sep 2016
                    • 43
                    Originally posted by 1FRY1
                    Matsan
                    i am not technician, just a user
                      • Sep 2016
                      • 43
                      • Synaux
                        • Mar 2012
                        • 1224
                        Yea...you can try changing the IUs, but you probably need to get a tech out to fix the underlying issue.
