bizhub C353 color quality
  • jakani
    • Dec 2014
    • 147
    Hello ,
    after i changed transfer belt color quality dropped
    any idea how to solve this ?
    • 14560
    Re: bizhub C353 color quality
    Was it a new transfer belt?
    Did you do Initialization and Stabilization and then run Gradation?
    • jakani
      • Dec 2014
      • 147
      hi ,
      thank you for replying
      yes i did initialization and gradation adjust .
      • Woxner
        • Jul 2011
        • 841
        try the reset and initialization. this reset everything to 0 this is different then last post
        • Desert Rat
          • May 2008
          • 1089
          I believe a new tansferbelt also comes with a transfer roller for the door.
          What part of the copy quality is incorrect? Did the counter reset to zero?
          How old are the drums?
          If it looks blurry try the auto clr registration adjustment.
          It's important to run the stabilizer before and after doing the auto gradation.
          After I do that the menu usually drops me out to the main svc menu.
          go back to the auto gradation screen and just press start.
          A description of the quality might help narrow down the possibilities.
          I'm assuming that the laser and scan optics are clean?
          DR
