BIZHUB 283 Default Service Mode Can't Access
  • rrrohan
    • Sep 2011
    • 1977
    #16
    Re: BIZHUB 283 Default Service Mode Can't Access
    does the 423 series not have a CE reset code you can supply tech support with? I know the 4 series and on have that option.
    • Alex1
      • Oct 2012
      • 285
      #17
      I don't think they provide that kind of service on the 423 series as when you go into service mode there is no CE password unless a tech has set one up as soon as I do stop 00 stop 01 it just goes to options menu such as System 1, System 2 ect. However someone decided to set up a CE password for this and cant enter or reset the password unless NVRAM firmware is reset or a complete wipeout is done on the machine and I'm here asking on how to do that wipe out as I don't have NVRAM firmware. The Konica 4 series came out with a factory password of 7292729272927292 again unless someone changes that CE password it will need a NVRAM firmware reset or maybe like you said you can call konica and they can help with the reset of that which I might doubt they would unless you log it in as a customer.
      • rrrohan
        • Sep 2011
        • 1977
        #18
        dumb question, have you asked customer who supplied service to the copier previously and called that company up and asked them?
        also there is a glitch that bypasses the password screen and you can just disable CE authentication. Found this out by removing fax kit before disabling it once. Went to service mode but before i entered code it gave error regarding missing fax kit. When i pressed menu it had put me into service mode without me ever typing the code in. Havent tried it in a while so may of been patched out.
        This was on a 4 series machine but might work on a 3 series as well
        • Alex1
          • Oct 2012
          • 285
          #19
          No not a dumb question at all actually I didtry calling and they couldn't help. I heard about the glitch which I tried on a Konica C364 sa.e thing CE password changed, I removed the fax came up with fax error went into service mode still asked for a CE password couldn't get in to disable it at all. I'll try it with the 283 let you k ow how I go.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            #20
            I know the 9272927292729272 came out with "4" series but never know. All I said was try it, how long would it take, 30 secs! Perhaps a tech was use to that password from the older machines and changed it. I've seen stranger things. Your screwed anyway what do you have to lose.
            • Alex1
              • Oct 2012
              • 285
              #21
              Tried it with no luck.
              • rrrohan
                • Sep 2011
                • 1977
                #22
                are you sure you havent triggered the access lock from to many bad password attempts?
                try clearing that then go back to trying the 92729272 and then 9272927292729272
                • Alex1
                  • Oct 2012
                  • 285
                  #23
                  I did not know I can clear that. Where can that be done. I've never had to do that.
                  [ATTACH=CONFIG]42534[/ATTACH]
                  • rrrohan
                    • Sep 2011
                    • 1977
                    #24
                    so strange i just had to help a Alex over the phone with this exact question
                    but see the image it shows the key sequence
                    The default lock time is only 1 minute so dont try any codes for at least that long
                    Last edited by rrrohan; 05-07-2019, 07:06 AM. Reason: default lock time is 1 minute
                    • Alex1
                      • Oct 2012
                      • 285
                      #25
                      Yes it was my self you helped. Thank you very much. I called your head office store location and they didn't know the code. What a small world you being on this forum. Thank you for the CE password and thank you everyone for taking the time to reply with help I really appreciate all your efforts.
