Firmware K9 and M1
Re: Firmware K9 and M1
Disconnect network lead when doing update.
Try to format the stick with windows format and partition utility rather then just right-click and format. Alson name it the stick AB or something short. Alocation size default and of course Format it as FAT32 .
OTHER THAN THAT.
You may have incorrect machine and type setup on you MFP.
Was there by ofchance new or 2nd hand (reset)board fitted?
Byting on bits. -
I've had some failures with the M0 firmware. When that happens I load only 1/2 the firmware. Then go back and load the other half separately. I've been successful with that. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
