C8000 cc101 code
  • beetle73
    • Dec 2010
    • 44
    [Dead] C8000 cc101 code
    Hi all
    I have a KM C8000 with a CC101 code
    Customer had power issues resulting in this code
    Replaced OACB,PRCB,Memoory control bd,2 PS units ,and Nvram from a working machine
    Instant code , machine will not boot
    Any ideas?
    Thx
  • mx6turbo89
    • Oct 2013
    • 154
    Re: C8000 cc101 code
    You can try a Main image processing board (IPB/M). That's supposed to be one of two possible faulty components (the other is the PRCB which you've already replaced).
    • beetle73
      • Dec 2010
      • 44
      Hi
      I appreciate the reply but according to the svce manual possible causes are PRCB and OACB which have both been replaced.
      • DigiMan
        • Jan 2013
        • 262
        Check your boards for fuses blowing out(even with the new boards)
        I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
        • mx6turbo89
          • Oct 2013
          • 154
          Originally posted by beetle73
          Hi
          Right you are, sorry, I looked up the wrong code.
          As Digiman says, check fuses and voltage points. Here's an ICP list that might help: https://www.dropbox.com/s/5ikktxabjt...%29_G.pdf?dl=0
          Check out ICP23 on the PRCB for 5V.
          • 907tec
            • 434
            I have heard that "recalling standard data" (found under Machine Adjustment) can help with this code, but it has not worked for me in the past. A few months ago I had a C7000 throwing this code, ended up replacing the PRCB and Color Reg/Gamma assembly. Have you looked at the "Troubleshooting Guide" at the end of the service manuals? There is a section in there related to C-C101 codes immediately upon startup - caused by pinched/grounded wiring in the vertical conveyance system.
            Either way, I would start by checking continuity across all the ICP's on the PRCB (both old board and new board).
            • beetle73
              • Dec 2010
              • 44
              Thx for the info
              We did find a blown fuse on the Prcb but have since replaced bd.
              Currently ohming out wiring harnesses
              • Quatro
                • Dec 2015
                • 78
                What is the previous status of the machine before the error occurred?
                Try to check the voltage supplied on OACB and PRCB if there is 5V,12V and 24V.
                Good Luck.
                • beetle73
                  • Dec 2010
                  • 44
                  Machine was working fine on the Friday.
                  Monday morning machine had CC101 code when powered up!
                  Fans are on but no pre-drive at all
                  • DigiMan
                    • Jan 2013
                    • 262
                    If it keeps blowing it even if you replaced it you can try(although its not reccomended for obvious reasons)shorting it.
                    • beetle73
                      • Dec 2010
                      • 44
                      Not a bad idea.
                      Still blowing fuse on the PRCB board.
                      Wiring harness on order.
                      • beetle73
                        • Dec 2010
                        • 44
                        Thx for all the ideas.
                        Nothing worked.
                        Customer upgraded!
                        • Peterzhao
                          Hi all
                          Any ideas?
                          Thx
                          Please check the power first before you do anything. I have one experence, the customer use two 110V brake to make the 220V power for Konica, later one brake cut off, the machine give us the same code.
