7 Series Paper Tray Size Recognition Issues
  • CraigW
    • Dec 2010
    • 417
    Anyone else seeing paper size detection problems on color & mono 7 series machines.
    In the cassettes. 1 had letter loaded and said 5.5 x 8.5 the other was 11 X 17 and had ?? marks displayed.
    Also had problems with the mono 7s cassettes as well.
    Found a few solutions but not much info as of yet.
    Thank You !
  • copyrooks
    • Oct 2013
    • 210
    Re: 7 Series Paper Tray Size Recognition Issues
    I have run into this issue on many bizhub 227s and c227s. Usually the 2 screws on the tray need to be adjusted and it works after. I read a bulletin about an issue at the factory where they werent set correctly. I havent seen the issue comeback once adjusted. Hope this helps
      • 23010
      I'm interested. Which two screws? Pictures please? =^..^=
      • copyrooks
        • Oct 2013
        • 210
        I attached the pdf for it
        • CraigW
          • Dec 2010
          • 417
          A few have worked after centering the screws.....some have not.
          Those star washers remind me of fixes I used on 7020 series cassettes.
          • tech51
            • 846
            Also the wiring to the sliding block on the rear can break causing size errors.
