Rebuild Fusing Parts for C6500
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    [Misc] Rebuild Fusing Parts for C6500
    Do I need some more parts to rebuild the fuser of C6500 at clients place. We usually replace the defective parts at 200/400K but this client heard of 400K PM for Fuser and want me to replace the parts. Please add or let me know which ones I don't need. Many Thanks and Regards for your kind feed back.
    Fusing Roller - 1
    Insulating Sleeve Upper
    Upper Fusing Bearing
    Fusing Roller - 2
    Fixing Bearing Upper
    Belt Regulating Sleeve
    Fusing Roller Lower
    2nd Fusing Ball Bearing
    Insulating Sleeve Lower
    Fuser Exit Roller
    Fixing Drive Gear B-28T
    Fixing Drive Gear M-22T
    Fixing Drive Gear M-26T
    Fusing Belt 251L
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    Re: Rebuild Fusing Parts for C6500
    Forgot the Part #
    A03U720100 Fusing Roller - 1
    A03U729500 Insulating Sleeve Upper
    A1UD723500 Upper Fusing Bearing
    A03U720201 Fusing Roller - 2
    A03U807800 Fixing Bearing Upper
    A03U725000 Belt Regulating Sleeve
    A03U720300 Fusing Roller Lower
    A1RJ721200 2nd Fusing Ball Bearing
    A03U722700 Insulating Sleeve Lower
    A03U722500 Fuser Exit Roller
    A03U808201 Fixing Drive Gear B-28T
    A03U809311 Fixing Drive Gear M-22T
    A03U809500 Fixing Drive Gear M-26T
    A1DU736000 Fusing Belt 251L
    • Synthohol
      Certified Konica Expert
      • 5863
      IMHO if i go that far i replace the 3 white one way gears and the shaft.
      heres the list for the future of the fuser PM cycle
