Di 650 will not scan from glass
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I was in a hurry and only had about 10 min to look at it, and I am sure I have overlooked something I should remember but, the machine will pull from EDH but when you put it on the glass it will not go green and make a copy. If I select a paper tray, it does not matter. It is not giving me a size detect error, it ask you to put one in the EDH. What have I missed?
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    DF open/close sensor?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Works fine, tells me to close lid if open, however if you lift and close lid and then put one in the EDH, it will not tell you to remove the original from the glass like it should.
      I even tried cussing at it, nothing worked.
      • Mark B
        • Jul 2006
        • 153
        I have seen this it is a dirty sensor in the adf. I do not remember which one.
        • Luther
          • May 2006
          • 682
          There are 2 switches that tell the machine the df is against the glass, front left of the df, when you lift the feeder you will see an actuator on the front left, remove the front left cover and see if the actuator is moving correctly, and the back center sticking out of the machine is a white post that actuates when you close the feeder, hope this helps
          • Luther
            • May 2006
            • 682
            Forgot to mention, check the original tray , there are 2 sensors that tell the machine the length of the original, have had the sensor holder break and the machine thinks there is an original in the tray, tip it up and remove the back and check the 2 sensors are secure,good luck
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Thanks for the feedback, I could not check it today as someone was using it with about a thousand more to go so I left. Will go back tomorrow and let ou know what I find.
