KM C550 - misfeed detected when a print job completes just before stapling
  • herbivore1
    • Nov 2016
    • 5
    I got a beautiful c550 from state auction. am a computer tech, have overhauled smaller laser printers. fairly new to bizhubs.
    When printing multipage docs that will be stapled in upper corner (saddle stitch stapling goes ok...) when the printing is done it detects misfeed. this sometimes happens just before the last page joins the rest - but usualy when they are all together waiting to be stapled.
    (Question: How do i determine what the error code is for a jam?)
    The device worked flawlessly. Until i formatted the hard drive. then it always jammed until i told it there was a punch kit installed... works fine now except this one issue!
    PS: I parted out a bizhub 250, kept just a few parts.. if anyone needs a doohicky off the carcass, you can have it for the shipping costs !
    Peace,
    Jason & Fischer Bender
    Ocean Shores Tech
  • Flash
    • 378
    Re: KM C550 - misfeed detected when a print job completes just before stapling
    Does it actually have a hole punch? If it does there are some sensors in there that may need calibrating. If it does not have a hole punch you need to uninstall it in the service mode.
    • herbivore1
      • Nov 2016
      • 5
      yes, PK-512 in my fs-608 finisher
      • habik
        • 2013
        I'd say firmware re-flash should solve it.
        Try 2 staples in middle or on the other side.
        Byting on bits.
        Firmwares HERE
        • herbivore1
          • Nov 2016
          • 5
          Byting on bits.
          Would love too...where can I gets me some firmware?
          Also, how do I tell what the jam's error code is?
          Thanks!
          • habik
            • 2013
            Enter service mode. Search for it on forum.
            Sent from my iDon't believe in marketing device using Tapatalk
            Firmwares HERE
            • herbivore1
              • Nov 2016
              • 5
              I literaly have spent > dozen hours on google, browsing the menus, going through the 1800 page service manual... and have learned a lot... but i still need a hand on how to find the jam error codes ... not sure what is my glitch...
              Please?
              • habik
                • 2013
                Counter > Jam
                Firmwares HERE
                • habik
                  • 2013
                  Utility/Counter
                  Check Details
                  Stop
                  00
                  Stop
                  01
                  Counter
                  Jam or Jam History
                  Firmwares HERE
                  • herbivore1
                    • Nov 2016
                    • 5
                    Utility/Counter
                    Check Details
                    Stop
                    00
                    Stop
                    01
                    Counter
                    Jam or Jam History
                    on this printer it is called machine management list.
                    FOUND AND FIXED THE GREMLIN...
                    Error # led me to this via google:
                    http://www.copytechnet.com/forums/ko...de-c-225b.html
                    Checked the DC PSU.... found... BAD BURSTED CAPS!!
                    1 HR 30 MIN LATER ITS FIXED.!!!
                    While I spend my work day and hobby time fixing stuff... this is my first industrial printer - its pristine (now) and cost me less than $90!
                    I AM SO BADASS!!
                    LOL !
                    Please excuse my NOOB excitment ...
                    THANK YOU!
                    • habik
                      • 2013
                      I AM SO BADASS!!
                      LOL !
                      THANK YOU!
                      Well done!
                      I must have missed the bit about you wanting machine reports.
                      Firmwares HERE
                      • Albonline
                        • Sep 2008
                        • 1153
                        Please?
                        look in manual, under soft switch settings, think its switch 11-7,but dont trust my memory, i dont!
