Konica Minolta C284
  • Fuzzylogic
    • Aug 2016
    • 33
    [Error Code] Konica Minolta C284
    Hello Again
    This machine works fine for about 500 pages then it wont print the complete document, hangs, and needs to be rebooted. This is a continuing cycle and in the Machine Management List the error code is E301. It has firmware A1610Y0-F000-G20-70 which was supposed to fix a similar problem but now this has popped up.
    Any suggestions.............
  • Synthohol
    Certified Konica Expert
    • 5863
    Re: Konica Minolta C284
    make sure spool to HDD is on under printer settings: basic settings.
    check HDD vacant space
    backup all to flash drive and do a logical format. then restore settings, check vacant space again.
    it shouldnt bail out like that.
    did you watch the memory%? when it happens?
    does it have the EK extra ram?
    • mx6turbo89
      • Oct 2013
      • 154
      Originally posted by Fuzzylogic
      Hello Again
      That's some old firmware. Try the latest base firmware (A1610Y0-F000-G20-72). It resolves 14 separate issues of the E301 code.
      • dickierock
        • 252
        I had something very similar recently with logged E301/machine hanging up. On our suppliers suggestion we replaced the firmware first,then Hdd, then the ram. This didn't work,it seemed to me it was something print/network related.
        Next I updated the drivers, and finally reset network card/changed the i.p address of the machine. It seems to be fine now so far so good.
        I would suggest to you to do the reverse of what I did.
