locked out of service mode due to to many failed attempts
  • rrrohan
    • Sep 2011
    • 1977
    Anyone know the procedure to reset the lock out on service mode of a 4050?
    I tried the procedure 1: At CE password screen pres STOP 09317
    Its meant to return to the normal operation screen but it doesnt
  • copyrooks
    • Oct 2013
    • 207
    Re: locked out of service mode due to to many failed attempts
    First try to reset copier. If no go, try an initialize system settings in security settings. If still no go try to login to web connection and do a initialize systems settings there. Good luck hope this helps.
    • Synthohol
      Certified Konica Expert
      • 5738
      i have just unplugged and waited 10 minutes and it let me back in.
      [edit] just checked the SM, says just cycle power and failed attempt counter is cleared.[/edit]
      • darry1322
        • Oct 2010
        • 817
        1. Touch Menu.
        2. Touch [Counter].
        3. Touch [Keypad].
        4. Press the following keys in this order.
        Stop -> 0 -> 9 -> 3 -> 1 -> 7
        (With this procedure, activate the access lock release timer to start timing.)
        5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released.
        • rrrohan
          • Sep 2011
          • 1977
          Thanks i will try on monday
          Sent from my SM-G900I using Tapatalk
