Bizhub C-6105 codes
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Bizhub C-6105 codes
    I know what this code is for, the dual scan backside cleaning home sensor. Wanted to know if anyone has found a solution for this. Several of the DF-701 (dual scan) feeders have been throwing this code a few times a month. Sometimes when I get to machine (next day) it is working fine. Some I had to blow out with canned air and it worked for a few months.
    When I was researching this on the internet I saw something about a F/W for the dual scan? Or is there a way to disable the backside cleaning feature, etc
  • vedder
    • 131
    Re: Bizhub C-6105 codes
    Hi, I came across this problem today on a c258, popping up with c-6105 constantly, stripped the relevent bits down, swapped the back cleaning sensor, switched off the adf in trouble reset, told the machine it had no adf fitted, nothing would get rid of the code, in the end i removed the dual scan board from the machine and it came to ready (without the doc feeder obviously), I have ordered the board up and hopefully we will get somewhere.
    cheers
