C6500 EROR CODE C2720
  • liondor1969
    • Jun 2016
    • 72
    [Error Code] C6500 EROR CODE C2720
    Haloo
    Plese hepl my,i have C6500,after code error J3201 i recive code eror C2720..mesage contact service,the C6500 pawer off.I lost al info on print contor..that happens when catch paperboard in C6500..
  • liondor1969
    • Jun 2016
    • 72
    Re: C6500 EROR CODE C2720
    Originally posted by liondor1969
    Haloo
    Hallo plese help my with this error code
    EROR CODE C2720
    • Synthohol
      Certified Konica Expert
      • 5942
      High voltage unit/2 (HV/2)
      Second transfer roller
      When the second transfer was
      ON, second transfer abnormality
      detection signal was continuously detected for the specified
      time.
      check the HV wire from the back of the xfer roller assy.
      put a strip of black electrical tape over the guide plate on top of the factory one.
      make sure the ground spring clip contacts the front of the roller well.
      • liondor1969
        • Jun 2016
        • 72
        time.
        Ok,i must to control this ..thanks
        • Texers
          • Apr 2012
          • 44
          if that didn't solve your code, replace the power block on the transfer assy.. A1DUR73300.
          • liondor1969
            • Jun 2016
            • 72
            Thanks,naw I have a red line on print,including non printing area
            • Texers
              • Apr 2012
              • 44
              Magenta Drum?
              • liondor1969
                • Jun 2016
                • 72
                Magenta Drum?
                Yes,magenta drum,I change magenta drum with cyan..than cyan have problems with blue line but in left side..on magenta the same drum make magenta line in left side :-)
                • tulintron
                  • Jul 2014
                  • 666
                  EROR CODE C2720
                  I found in the field, another technician changed the 2nd transfer electric poles with discharge guide in the bottom of the ADU, under the 2nd transfer.
                  After correcting the error, defect is over.
                  • liondor1969
                    • Jun 2016
                    • 72
                    I have this problem only when using drawer 5..big ..a technician says it's a firmware problem. wen i use paper drawer 1-2-3 and i have paper jam..everything clean and start ok..than wan i have paper jam on drawer 4-5 after i clean all,i become this error cod C2720.I want to try to do firmware updates..if you have other suggestions.
                    • lartis.aineias
                      • 78
                      I had this problem in konica C6000 and finally the problem was in the up 2nd transfer holder. it was cracked at the point where it gets current!20210118_111728.jpg20210118_111747.jpg
                      Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
                        Originally posted by lartis.aineias
                        I had this problem in konica C6000 and finally the problem was in the up 2nd transfer holder. it was cracked at the point where it gets current![ATTACH]47897[/ATTACH][ATTACH]47898[/ATTACH]
                        4 year dead thread...
                        • allan
                          RTFM!!
                          • 5462
                          Hehe just adds to the thread. Who knows who will search for this next.
                          Whatever
                          • Robin (ACS Collective)
                            • Nov 2021
                            • 22
                            Yeah me
                            Any news on this error? I got C6000 and I am constantly getting c2720. I checked and cleaned the roller but nothing. Getting magenta lines on the roller so changed drum but still everything as it was...
                            EDIT:
                            lol - just gave my last try, changed the roller and everything goes xD
                            cheers everyone
                            • TEST10
                              • Jun 2010
                              • 67
                              I resolved in the same way!:frio:
