Allo help me bhc 280 yellow missing
  • Syuk
    • Jan 2017
    • 13
    How to settle that problem
    Bhc 280 yellow missing
    I already Change drum
    And develop
    But that problem still have
    Please help me and give me some idea
  • guitar9199
    • Sep 2016
    • 1100
    Re: Allo help me bhc 280 yellow missing
    Have you checked and cleaned the laser for that color?
    • Syuk
      • Jan 2017
      • 13
      Owh think same like u but I already clean laser but still same...I think tomorrow I try Change another laser
      Thx for give me ide
        • 14791
        Which P code is being displayed when you touch the oil can?
        • Syuk
          • Jan 2017
          • 13
          Allo can I know what oil
            • 14791
            On the screen there is likely an oil can showing, it is a warning. If you touch it with your finger it will display the warning. If it is there it will come up as a "P-XX"
            • Syuk
              • Jan 2017
              • 13
              That machine no give any warning
              • REGSIS
                • May 2016
                • 435
                Try to run image stabilization, it shoud give you the error on bottom of display (triangle like oil can) press it and it will show you the code.
                • Syuk
                  • Jan 2017
                  • 13
                  That code c2555
                  • Synthohol
                    Certified Konica Expert
                    • 5846
                    (2) Procedure
                    Step Action Control signal Location of electrical components
                    1 Perform image troubleshooting procedure if image density is
                    low.
                    2 Reinstall developing unit - -
                    3 Reinstall toner cartridge - -
                    4 Check the connector between developing unit-FREYB CN4,
                    CN6, CN8, CN10 for proper connection and correct as
                    necessary.
                    5 Check the connector between FREYB CN1, CN2-PRCB
                    CN4, CN5 for proper connection and correct as necessary.
                    6 M6, M7 operation check PRCB CN13-12 to 15 (M6)
                    PRCB CN13-16 to 19 (M7)
                    J-21
                    7 M8, M9 operation check PRCB CN12-9 to 12 (M8)
                    PRCB CN12-13 to 16 (M9)
                    J-10
                    8 If the toner empty sensor and its surroundings inside the sub
                    hopper are dirtied with toner, clean them.
                    9 Change developing unit -- -
                    10 Change FREYB - -
                    11 PRCB ICP3,4 conduction check - -
                    12 Change PRCB - -
                    N.1. bizhub C220/C280/C360
                    S.44. C2551, C2553, C2555, C2557)
                    • REGSIS
                      • May 2016
                      • 435
                      Remove yellow drum and yellow developer unt.
                      On dev unit check magnet roller for developer loss (lower density, voids) compare with other developer units.
                      Check yellow toner hooper (is it empty or is it full of toner).
                      Is customer experienced paged fully covered with yellow?
                      This might be HV unit problem but also can be caused by bad drum unit(s) or overlife drum unit or even transfer belt unit (overlife) or simply dev units reached end of life (or near).
                      • bunchieattia
                        • Aug 2017
                        • 4
                        Hello
                        There is flex between the Flex that connects to the laser Bin
                        And develop
                        • Hansoon
                          • Sep 2007
                          • 3389
                          * Off Topic * @ Synthohol: From where did you get that fancy "Schematics"? It's not in MY Tech Manual. Would love to have such for the BH-C-280 series and the BH-363/423 as well............
                          Hans
                          • Synthohol
                            • 5846
                            page S-50 in the field service manual.
                            almost every manual has an "S" section parts layout.
