Bizhub 206 SMB scan error codes
  • dogsbody
    • Jun 2007
    • 289
    Hey all, I have a Bizhub 206 that refuses to scan SMB. The folders are shared correctly however no combination of file path username/password works. It does print a TX report with an error code, however I cannot find the errors listed in any manual. The errors are 0104 and 0115 depending on how I've set the scan up. If any one has a list of what these errors are and can share it'd be much appreciated. Thanks.
    The force will be with you always.
  • Woxner
    • Jul 2011
    • 839
    Re: Bizhub 206 SMB scan error codes
    is there a firewall stopping it. did you turn on file sharing in the network not just the file. also what os are you using.
    • Gaffers01
      • May 2011
      • 334
      Here is the list of error codes hope this helps to narrow down the problem. Sorry the list looks a bit confuing where ive copied and pasted it but if there is a space next to the code it belongs to the Corrective action above
      6.1Network error code list
      Error code
      Category
      Contents of error
      Cause
      Corrective action
      E100
      Cannot connect
      SMTP server
      A connection with the server could not be established.
      • Make sure that the Ethernet cable is correctly connected.
      • Check the function settings on the [E-MAIL SETTING 1], [EMAIL SETTING 2], and [NETWORK SETTING] menus.
      • Ask the network administrator if the network is operating normally.
      E101
      POP3 server
      E102
      DNS server
      E103
      FTP proxy server
      E104
      SMB server
      E105
      NTP server
      E11E
      LDAP server
      E106
      Server error
      FTP server error
      Scanned data could not be properly uploaded to the FTP server or the SMB server.
      E107
      SMB server error
      E108
      Wrong password
      FTP server
      Login to the server failed due to a wrong password.
      • For the POP3 server, check the function settings on the [E-MAIL SETTING 2] menu.
      E109
      SMB server
      E10A
      SMTP server
      E10B
      POP3 server
      E10C
      LDAP server
      E10D
      Server memory full
      SMTP server
      A memory overflow occurred in the SMTP server during E-mail transmission.
      E11F
      USB memory full
      USB memory full
      The memory capacity of the USB is less than the data size to be scanned.
      Either increase the amount of available space by deleting files on the USB memory, or use another USB memory that has more available memory space.
      E10E
      Cannot get IP
      DNS can’t get LDAP IP
      An IP address could not be obtained from the DNS server.
      E10F
      DNS can’t get SMTP IP
      E110
      DNS can’t get POP3 IP
      E111
      DNS can’t get FTP IP
      E112
      DNS can’t get NTP IP
      E113
      Communication error
      SMTP server
      Communication with the server failed due to a problem in the main unit or unavailability of the network or server.
      • Check the communication result report.
      E114
      FTP server
      E115
      SMB server
      E116
      POP3 server
      E117
      NTP server
      E120
      USB memory
      Communication with the USB memory could not be established.
      Check that the USB memory is connected correctly.
      • dogsbody
        • Jun 2007
        • 289
        Thankyou,
        Woxner, it is server 2012, I trust the IT company that set up the share. They have existing bizhub c280's and 223's that I was able to configure and get to work.
        Gaffers01, thankyou but the specific errors I am getting are not listed, I'm was hoping for something a bit more specific so I can narrow down the error to something specific. The c280 would say something like "login error" as well as give me an error code that I could look up for something more specific.
        Cheers.
        • Gaffers01
          • May 2011
          • 334
          Instead of "0" the error codes are "E" in the service table above.
          So 0104 is E104 and so on.
