Bizhub 452 Error C-C163
  • Bhenz19
    • Dec 2016
    • 8
    Bizhub 452 error code C-C163
    I changed all of the boards and it gives me error C-C163.
    Hope you could help me guys..
    Thank you.
  • Max
    • Oct 2011
    • 561
    Re: Bizhub 452 Error C-C163
    Was it giving you the error codes before you changed the boards? Have you followed the board replacement instruction as per service manual?
    • Bhenz19
      • Dec 2016
      • 8
      It was giving error code C-930 before I changed the board and unfortunately sir we dont have the service manual
      We just tried to change the boards from our spare machine.
      • Synthohol
        Certified Konica Expert
        • 5849
        wrong model firmware error is detected in the engine during initial connection to the engine is being checked.
        EEPROM and or PRCB are relevant electrical parts.
        did you put the original EEPROM on the replacement board? also you cant just replace both boards at once you may get lucky one at a time but make sure you use the original EEPROM.
        btw could not find c930 error in the manual.
        • Bhenz19
          • Dec 2016
          • 8
          We did not use the original EEPROM sir because we thought it was the one that is faulty so we tried to swap tha whole boards along with the EEPROM from another machine..
          Thanks a lot sir for the ideas and for the sv manual.
          God bless
