Konica c280 Misfeed 3003
  • mearmi
    • Oct 2010
    • 350
    Hi
    Konica C3003 misfeed
    replaced registration clutch and fuser
    still same problem
    find the attached Misfeed history
    many Thanks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4697
    Re: Konica c280 Misfeed 3003
    Is it happening from other paper drawers & manual feed tray?
    I'm sure you checked this but are the clear plastic guides on each paper feed assembly sitting right? It is very common for the tabs on guides to break in these models, then guides don't sit right and can cause intermittent or constant jamming.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      Originally posted by mearmi
      Hi
      still same problem
      many Thanks
      You neglected to mention........Does the machine have a sorter/finisher? What is the meter count? Is the paper stopping exiting the fixing unit or before the xfer ? Also, some jamming issues on this model were addressed by firmware updates. Install latest firmware if you have not already done it.
      You were smart to replace the fuser for the PS3 jams and the reg clutch was a good idea also.
      That being said............My initial guess would be an issue with the reg flag sticking or reg sensor itself.
      • mearmi
        • Oct 2010
        • 350
        Thanks for your reply
        yes machine has finisher installed.
        paper stops at the fuser entrance.
        Regards,
        • HitMan
          • Aug 2015
          • 170
          I had an issue with a Konica just kept jamming before fuser entrance. The little spring on the registration sensor needed a bit more tension and the sensor on the door in the middle next to the fuser. Give the spring another turn so the little flag snaps back faster
