Bizhub 363 scan to email
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Have a customer with a Bizhub 363 and they can scan to folder just fine. They want to scan to email but are having difficulty setting it up. Stopped by to install the most recent complete firmware package I downloaded from the Konica website thinking this would update any security protocols or other items and that would allow the customer to configure the scanning to email. Their IT guy still cannot setup scan to email even after completely installing the firmware(223_283_363_423_a1ud0y0-f000-g00-d6.exe). Any suggestions on how to proceed much appreciated.
  • copier tech
    • 8174
    Re: Bizhub 363 scan to email
    Need a bit more info to help
    Check your gateway & DNS are correct.
    What is the smtp address & port number?
    Have you tried logging in via a web browser to confirm the email authentication info is correct?
    • peter42
      • Jan 2012
      • 110
      admin and machine adress filled: "KM363@yourmail.com ?
      Allowed in Customers Mail server?
      Access alowed in Gmail/somethingelse for machine?
      MFP must be setup like a complete Emailclient like MS-Office-PC.
      • emujo
        • Jun 2009
        • 3009
        The best way to start troubleshooting this is to look at the MFP job log and determine why it's failing. The usual culprits are server connect error, or login error. There may also be some FWD TX errors, but these are less frequent. Divide and conquer.
        Server connect error--MFP is unable to even make contact with the mail server--could be ports or TLS/SSL settings, DNS resolution, etc..
        Login Error--MFP can contact mail server, but request is being denied by host..
        You need to provide this info, along with the type of mail server you are working with..exchange, gmail, go daddy etc..
        I also like to test with a simple, low security, gmail account for testing purposes..It's always nice to be able to say "mr customer, the MFP can send mail, just not with the settings you are providing me". Emujo
        • allan
          RTFM!!
          • 5462
          Jip thank google for that, works every time.. almost every time. 1 out off 3 attempt with info provided by the customer will work, nice and frustrating.
          So i use my own gmail account to test if the machine is ok to go.
          Now i fail once and ask the customer if its ok to use gmail. Or explain to them that they need to get the info or create a mail account for the machine.
          Then they would happily allow me to use gmail. them having to deal with their IT/service provider does the trick.....
          Whatever
          • rrrohan
            • Sep 2011
            • 1977
            If it works dometimes it might be a dns issue assuming your smtp is via host name not IP
