C454e not printing PDF's
  • danetime
    • Jul 2014
    • 8
    #16
    Re: C454e not printing PDF's
    Is there any error codes in history or does the machine ever have "internal error" message before rebooting? Update the firmware or re install the firmware. I find PDF causing rebooting is a sign that the NVRAM is about to go.
    • Max
      • Oct 2011
      • 546
      #17
      Before you start spending money on it reset it via service mode. If that doesn't work try the reset tool.
      • mo0651
        • 1054
        #18
        Did you go into service mode and do internal memory tests? You stated firmware was at latest level, but did you re-flash? Reseat memory? What have you done?
        • JSC
          Gimp
          • Dec 2006
          • 618
          #19
          Yes tested all ok, but changed memory and HDD as well
          Originally posted by Woxner
          make sure the driver is on raw. also check the network speed. i had several hang up. changed the speed and tada never called again about this problem. they were printing large pdf's.
          Yea i've had the same before did all the above no change, but I don't think this is a driver or network fault as it locks up printing PDF's from a stick plugged into the usb port.
          No error codes reported. Initialized the machine (several times) Firmware updated to the lattest.
          Yep done, still no joy..
          The gene pool could use a little chlorine.
          • JSC
            Gimp
            • Dec 2006
            • 618
            #20
            Sovled..
            Fitted main board - now working fine.......
            • Tech Helpdesk
              • Jul 2015
              • 112
              #21
              Originally posted by JSC
              Sovled..
              Never cheap is it.
              • JSC
                Gimp
                • Dec 2006
                • 618
                #22
                Originally posted by Tech Helpdesk
                Never cheap is it.
                is'nt that the truth.....
