C454e not printing PDF's
  • JSC
    Gimp
    • Dec 2006
    • 618
    [Misc] C454e not printing PDF's
    Hi.
    Have a strange one with a C454e that will print a few PDF's then just lockup/frezzes and the device has to be rebooted. Doesn't seem to mater which type of PDF reader is used or how the PDF was created. The fault only happens with PDF's, it prints everything else fine.
    Have used multible drivers, changed memory and HDD. It's on the latest firmware and function level. Next step would be to change the main board unless someone has a better idea?
    Thanks.
    The gene pool could use a little chlorine.
  • copier tech
    • 8176
    Re: C454e not printing PDF's
    Try plugging in your laptop directly & then printing a pdf.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Does the same.
      • Methmann
        • May 2009
        • 72
        I have had this issue, however on a C280. But it happened when printing PDF from Microsoft Edge browser :-) So told the customer to print from Internet Explorer instead.
        • Tech Helpdesk
          • Jul 2015
          • 112
          Hi mate,
          What type of driver is being used ? and what printing protocol are you using ?
          Make sure on the PDF that 'Print as Image' is not selected
          Regards
          • JSC
            Gimp
            • Dec 2006
            • 618
            Originally posted by Tech Helpdesk
            Hi mate,
            Regards
            Have tried all the correct Konica Minolta drivers eg, PCL, PS, Clasic, Universal. it also crashes if sent as 'Print as Image'. used Adobe reader, Foxit, Nitro all with the same result. Works for a while then crashes/frezzes.
            Scratching my head on this one.
            • Tech Helpdesk
              • Jul 2015
              • 112
              Try forgetting the PC side and look at the ops panel. Go into User Settings and turn off spool.
              See below,
              Regards
              • JSC
                Gimp
                • Dec 2006
                • 618
                See below,
                Regards
                [ATTACH=CONFIG]35583[/ATTACH]
                Changed the settings to match yours, worked for 3 pdf's then crashed out
                • copyrooks
                  • Oct 2013
                  • 210
                  try a different pdf reader program like sumatra. See if any difference.
                  • JSC
                    Gimp
                    • Dec 2006
                    • 618
                    Have used about 4 diffrent readers all the same problem. also printing test PDFs that I have used lots of times with no issues.
                    • allan
                      RTFM!!
                      • 5462
                      Try direct submission other wise thru PSWC or pagescope direct print. If that works...
                      Whatever
                      • peter42
                        • Jan 2012
                        • 110
                        Try to print PDF directly from USB-Stick.
                        Then you have Networkinterface out of the printing pipeline.
                          you were instructed to make sure that PRINT AS IMAGE is OFF
                          • JSC
                            Gimp
                            • Dec 2006
                            • 618
                            yes and I tried it print as image off! And print as image - no change
                            works...
                            no joy.....
                            Tried that already, interestingly the machine works for a lot longer period but still crashes after a while.
                            i think I'm going to bite the bullet and order an MFP board....
                            • Woxner
                              • Jul 2011
                              • 851
                              make sure the driver is on raw. also check the network speed. i had several hang up. changed the speed and tada never called again about this problem. they were printing large pdf's.
