Konica c253 transfer belt reset
  • DOE
    • Mar 2010
    • 258
    Have a Konica c253 with the replace transfer belt message. The unit is still good is there a way to reset it other than using a chip and if not where do I get the chip to reset units. Thank you
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Konica c253 transfer belt reset
    Here's the problem. If you reset the counter the voltage supplied to the belt will change and ANY wear on the belt will show.
    Either replace it or BEFORE it calls for anything change the setting to not display EOL warnings.
    Too late now, never got one to stop once it's already displayed.
    Fwiw it's a 1/16th Amp fuse (.063A) IIRC you need a 00 tip Phillips to get the cover off the fuse.
    Good luck.
