Bizhub 423, Error C-E002
  • Biz2000
    • Aug 2013
    • 13
    First of all this bizhub 423 has No HDD installed. And so this error does not make sense and I cant clear it. I already tried trouble reset and turning on and off. I also reset copy date and history data. Does anyone have any ideas for me to try or who has already experienced this problem.
    Thanks for any help
    Ktech
  • mo0651
    • 1054
    Re: Bizhub 423, Error C-E002
    The HDD was installed at factory on that model. code stands for failed MFB.
    • Biz2000
      • Aug 2013
      • 13
      thank you very much. I did hear that before but I have several in the field without HDD's and they seem to work fine. Because this particular customer does a lot of faxes, prints and copies by many empoyees I decided to put a hard drive in both of the bizhub 423's. Once I put the HDD in the one with the error the copier finally came on without the code. I hope this will quell the tide.
      • Woxner
        • Jul 2011
        • 854
        after you turned the hdd on did you do a logical format? I doubt the mfp is bad if it was working before you put in the hdd. although these came with hdd they do work just fine without them.
        • REGSIS
          • May 2016
          • 437
          He put HDD in the machine with error and after that error was gone. problem solved.
          BTW HDD can be turned OFF in 3, 4 and 8 series without errors.
          • Biz2000
            • Aug 2013
            • 13
            Mr. Wayne...
            When the error first popped up yesterday, the machine was without HDD installed and in the service mode was set to "HDD NOT INSTALLED". Is that what you are referring to by "Turned Off"?
            The copier I am referring to with that error, is one that I had to swap the NVRAM because it was locked out with the "Authentication" and "Security Card", and that was the only way of getting around that.
            Do you have any knowledge on a back door to get past the HDD Passcode? So I can turn off all of that crap and use the machine without swapping the NVRAM.
            Thanks for any help
            ktech
