C6501 Odd Yellow issue...
  • methogod
    • Dec 2008
    • 921
    [CQ] C6501 Odd Yellow issue...
    Test pages off the engine print good.
    Never seen marks like this, swapped drums, and coronas. Service is due all around (DRUM, DV) but wanted to get a base line before putting money into it.
    Test print off the Engine (TEST PRINT)
    https://www.dropbox.com/s/ajrqdvqbg2...05.24.jpg?dl=0
    OFF the FIERY (after updating to latest version)
    https://www.dropbox.com/s/1vbjmnims9...04.44.jpg?dl=0
  • methogod
    • Dec 2008
    • 921
    Re: C6501 Odd Yellow issue...
    bump...
    where is black cat...
    • tulintron
      • Jul 2014
      • 668
      what's the problem?
      Print a test pattern 53 with 180 yellow
      https://www.copytechnet.com/images/smilies/cool.pngNada como dia apรณs diahttps://www.copytechnet.com/images/smilies/cool.png
      • methogod
        • Dec 2008
        • 921
        Ok, here are better photos...
        Since i have posted...
        Replaced yellow DV unit, Next Developer.
        Replaced belt unit
        Replaced lower transfer roller
        (Machine has been in storage, trying to get it back up and running)
        Seems like issue comes from RIP, but no way to be sure, that I can figure out. Why only yellow?
        2mil on clock. Super Clean from what I can tell.
        Test Mode 53, 180 of 255
        Found
        Where there is yellow it should be white... Not sure what to do next.
        Found
        Test 5% prints look fine too...
        Found
        • methogod
          • Dec 2008
          • 921
          drop box doesn't link direct links
          • methogod
            • Dec 2008
            • 921
            you guys have been sucky lately.
            FIERY CABLE FAILED....
            thanks,
